raisincain
- May 31, 2013
- 2
- 3
Couldn,t find the answer, When I push the reverse lever it shuts off the PTO. I know it,s a safety feature. How do I by pass that?
The switch is right there by the reverse pedal . It is only held in place with one screw ( 1/4 " if I recall correctly ) Loosen that bolt with a wrench from the top , spin the button down so it doesn't contact the pedal , re-tighten the bolt. No need to unplug anything.
I found it 5/16. thanks
