- Feb 19, 2020
- 118
- 12,664
Similar but the Cub Cadet RTZ system disengages the PTO clutch only. On some riding mowers the reverse system kills PTO only also but the operator must cycle the PTO switch to re-engage the PTO once going forward again.I am not sure if it is mandated on residential zero turns but quite a few of the residential box store mowers i have worked on have that feature. None of the commercial ones do. Maybe it is like the tractor mowers that kill the engine if you reverse with the blades engaged.
With RTZ system if back over an object as soon you pull the lap bar out reverse you go ahead just make mince meat out whatever you ran over.
Kinda wondering which Husqvarna ZTR that has a manual PTO as I haven't seen one here.
