Engine Runs with out spark plug
Carscw
Have asked this a few times and still can not find out why.
5hp Briggs will not start getting gas pull the plug and ground it next to the plug hole and it runs put plug back in and it will not run.
20hp briggs twin same thing just pulling one plug and ground next to the plug hole.
Many have said no way it will run like this but it does.
And of course someone said could be your valves
Sent from my iPhone using LMF
Lawnranger
Theoretically, an engine needs three factors present and in the correct proportion to start and run properly - the correct air/fuel ratio (fresh, quality fuel is a must), sufficient compression (arguably 90 P.S.I. or better) and sufficient spark at the correct time. How bout you make a video of the engine running with the spark plug grounded next to the hole, as you claim, so we can see what you are talking about? And yes, it's probably the "valves".
RFouce
Funny you should mention this, my Briggs will not start and run unless I unplug the spark plug wire and keep it about 1/4 inch away.
Can you tell me how it works, posted the videos awhile back and no one could solve the problem. This is a old mechanic secret.
1 Lucky Texan
no, i don't know - might involve some gasoline in the crankcase and somehow having the spark jump from the piston to the head - maybe some kinda insulating material on the head bolts so the head doesnt short high voltage to the cyl? secret wiring from the coil to the head?
maybe an internet search would find the secret
I'll look around too when i get the chance
mullins87
I had an engine do that once. Turns out there was a short in the plug wire where it came out from under the flywheel shroud. When I moved the wire to unplug it, I removed the short.
fireman9513
Have you replaced your spark plug?
It's possible your plug Is shorted inside and this works because it makes the spark hot enough to jump the short
RFouce
Very interesting, as i am on duty today i will replace the wire tomorrow and see if that helps, thanks all who replied.
fireman9513
So did you try a new plug? That is the easiest thing to try first.
If you don't try that first but start replacing other more expensive parts you may be wasting your time!
