- Nov 29, 2014
- 65
- 24,980
Do you run a bagger ?
Baggers emit very fine dust that can get sucked into the engine and wear the rings
I have done quite a few re-rings on Timecutters fitted with Kawasaki engines because the air filter is a bad design and easily leaks if overtightened .
The solution is to fit the FX filter and if the customer will not do that then a heavy dollop of rubber grease .
