No luck. I know I had air flowing freely throughout the air chamber. There is one very small hole in the throat beside the choke plate where the air mixture needle will protrude when the air mixture screw is fully seated then three even smaller holes in the throat behind the choke plate. All of those are clear and air flowing freely. Air flowing freely front to back on both sides as well. When i first started it, it ran fine for about two minutes, almost long enough, it seemed, for the carb bowl to fill up and then it started running rich again, just like before. It is still running rich at idle, particularly high idle. At high idle the engine will sputter every 3 to 4 seconds and spit out black smoke. It ran fine under load with the PTO. As I left it at high idle it quickly got progressively worse and then when I engaged the PTO it bogged down and died. When I tried to start it again it began to backfire and would not start. I did not continue trying to start it. I removed the flywheel to check the key and it is fine. I'm going to recheck the valve lash. Suggestions?
