bones774
Hi I have an Ariens A22 with the RS80 transmission giving me problems.
newbie here thank for any help. i have an A22A46 with trans problem, RS80. Goes very slow in forward and pedal all tthe way pushed,
I went thru the trouble shoot steps, and where it fails is when the foot pedal is all the way forward I cant rotate secondary pulley in CW direction (or it may be beyond my strength), Neutral rotation is good and reverse rotation is good,.
Differential check is also good.
When stepping on trans pedal i feel the detentes catching and they feel good but forward pedal is much to uch extension.
I cleaned all the muck from inside there and removed variator and cleaned under that, probably first time in 3 years since new.
Any info or thought s, please help
thanks
thanks
