RPM's on a HRX2173HYA
Bullitt66
What is the best way to check the rpm's on this mower? Is there an easy way to do it yourself with an inexpensive tach?
Here are the specs for engine speed; be sure the engine is fully warmed up when checking / adjusting...
* Throttle in SLOW position, blade control = OFF, adjust the throttle stop screw to obtain 1,700 +/- 150 rpm
* Throttle in FAST position, blade control = ON, engine should be turning 2,950~3,100 rpm.
See images below for details.
Thanks for the info. I'm going to order the tach. Where do you place the tach so that is picks up the vibrations?
