Right wheel loose
Brinx777
Right front wheel spins and not tight against frame. No warps, bends, etc. Drive axle lays against frame. Believe missing/broken part that fits in hole. Can someone help? No diagram with part to order to replace. See attached pic. IMG_20200315_193005702_compress37.jpg
Please post the model and serial numbers of the unit so we have a starting point as to how to help you.
April 12, 2012 model.
You are missing the bearing assembly PN 532421836 . The groove is for the snap ring in your picture. Part of the old bearing is also still on the shaft.
You’re missing the bearing assembly, part number 421836. You can order this part from Sears. Go to Sears parts direct with your model number and you can download an owners manual which includes a parts diagram.
I would guess that you are missing item 17 on the following diagram from the drive
Looks like we were all posting at the same time Startech, and Rivets.
Actually both part numbers are superseded to 587070202 with a list price of $3.99 and my distributor only has 118 of them in stock so you better panic. :p
So part #587070202 is what I need. Do you Gabe have a website that I can order it from.
Appreciate your help!
Just Google the above part number and it will give you a list of site that sells it online. It is you choice of who to use.
