Right front wheel spins and not tight against frame. No warps, bends, etc. Drive axle lays against frame. Believe missing/broken part that fits in hole. Can someone help? No diagram with part to order to replace. See attached pic.
You are missing the bearing assembly PN 532421836 . The groove is for the snap ring in your picture. Part of the old bearing is also still on the shaft.
You’re missing the bearing assembly, part number 421836. You can order this part from Sears. Go to Sears parts direct with your model number and you can download an owners manual which includes a parts diagram.
Craftsman 917370600 gas walk-behind mower parts - manufacturer-approved parts for a proper fit every time! We also have installation guides, diagrams and manuals to help you along the way!
www.searspartsdirect.com
Looks like we were all posting at the same time Startech, and Rivets.
Actually both part numbers are superseded to 587070202 with a list price of $3.99 and my distributor only has 118 of them in stock so you better panic.
