Right Angle Gearbox.
Castleford
I run a used MTD snowblower attachment on my lawn tractor, P/N is 190-032.
I want to change out the lubricant in the right angle gearbox,that P/N is 917-1714A.It is driven with a belt from the tractor's PTO.
I've googled for info on gear oil type and proper fill level with no luck, I removed the plug to look and the oil is about 1/4" from the top.
Does anyone know the proper weight/type of oil to use in these units?
Scrubcadet10
Moderator
Staff member
Looks like most people use "00 grease" or 80w90 gear oil. I
or contact MTD and ask them
it is most likely a peerless right angle drive, and both 00 grease and 80w90 are both used. I haven't looked at my old peerless manual yet but I would suspect either would be safe.
mechanic mark
So, you don't know either?
Call MTD Technical Support at 1-800-269-6215, or 1-800-800-7310 EST, 9 A.M.- 7 P.M., have complete model & serial numbers handy, the model number you posted was incomplete or incorrect.
Castleford
