KrashnKraka
- Jun 15, 2015
- 6
- 352
I picked up a head gasket the other day.
Is anyone else agreeing that my 30 year old mower could be carboned up in the head/piston area and this could be the problem?
Doesn't read as such to me, a lot of variables in 30 years of time.
Like only 40 hours of operation 'cos each year it is used the engine
appears to overheat so back in locker it goes till next year, year in
year out.
:laugh:
Srsly, other symptoms would have appeared long before serious
carbon buildup. You only report one consistent symptom.
Buuuuut... as a test you can try getting the unit hot, at night.
In the dark you will see loose burning carbon particles flying out of
the exhaust. If in numbers it is best you strip and decoke.
I still don't believe that is going to fix your problem - it may just prove
another symptom.
My money is on a timing issue, or wrong plugs.
-- flipping cards an ' readin' sign
