Hello,
I am new to this forum and hoping someone has some ideas. I have a Craftsman riding mower with a Briggs 15.5hp OHV engine. When I turn the key it turns over slowly and acts as though the battery is dead. I took the battery to a shop and had it tested and they said it was fine. Today I checked my ground cable and positive cable for corrosion and connection. All appear fine. So here is the question...what am I missing, is there a voltage regulator on these that could be bad? Is there a solenoid on these that could be bad? Could the starter be the problem? Is there a way to check these items out?
Thank you in advance for any ideas.
