Does pouring baking soda mixed with water (1 cup BS to a gallon of water) after pouring acid water out of battery clean the corrosion off the plates an revive the battery?
Acid is needed in a battery to cause the plates to charge, Baking soda neutralizes acid...so what do you think?
There are videos on Youtube about reviving batteries with Epson salt, using distilled water.
many sellers on Ebay with battery restore solution...which I believe is the Epsom salt solution.
do a search there and see if you want to try it.
For what a new battery cost why would you want to. I have seen them on sale for less then 20 dollars. Then you don't have to handle battery acid.
Your right about thatNew jeans...$15 dollars
Just curious to see if it would work.
