Let me look up some tech details....after you tell me the full serial number (back upper mower deck) It is the form of MXXX-1234567
Robert - thanks for the quick response:
Purchased July 1999
HRB215-JK
MZBA-6342486
I did remove the transmission since my last post and the level was full. I did notice that the seal that covers the fill hole on the vent hole side (next to metal cover) was very dirty. The vent hole appeared clogged. So I removed the seal from the metal cap and cleaned. I topped off with Honda fluid and put back together.
Prior to putting back into mower, I tested the transmission and it seemed to be working. With my wife holding drill on shaft, I would engage the lever and the drive shafts would turn. This time however, I gripped the drive shaft to see how strong it was and it was absolutely strong, i.e., more than enough to move mower. Again, it seem that the transmission was working perfectly. I would release the lever and the drive shafts would stop turning, at a higher speed, it was even harder to hold the drive shaft with my hand.
So I thought it was fixed this time around and put transmission back into mower. Filled with gas and oil, fired it up and still no motion. No motion on the ground, if I lift the back of the mower up, the wheels turn, set on ground and no motion - arg!! I have the adjustment pretty much at the max as far as transmission cable tension is concerned.
I compared the transmission cable tension with my newer HRX217K2 HXA, MAGA - 1688490, and it seemed to be the same.
So I am completely at a loss as to why this is happening.
Questions:
Can you overfill the hydrostatic transmission? I had a hard time determining where the low and high fill levels were - any help appreciated.
The small fill hole has very small reservoir where the rubber seal goes and I filled that to the upper limit. Of course when I put the seal on some fluid leaked out. Again, I tested (after filling) with my hand and the transmission seemed to be strong.
I really appreciate your help and hope you can help me resolve this. Thanks!
