Reset oil meter after oil change Troybilt mustang 50
Tyoung
I changed oil filter and gas /air filter
It’s still showing change air/ oil low on meter
Tyoung
It’s trying to shut down while mowing
Are the sensors bad?
cpurvis
Most installations which have maintenance minder devices have a reset feature. Have you done that? Check in your owner's manual.
Not all hour meter have a maintenance but instead an auto reset after a predetermined time has passed.
Also need the model number from the serial number tag see how your mower is setup.
