I changed oil filter and gas /air filter It’s still showing change air/ oil low on meter
Tyoung Forum Newbie Joined May 22, 2020 Threads 1 Messages 2 May 22, 2020 / Reset oil meter after oil change Troybilt mustang 50 #1 I changed oil filter and gas /air filter It’s still showing change air/ oil low on meter
Tyoung Forum Newbie Joined May 22, 2020 Threads 1 Messages 2 May 22, 2020 / Reset oil meter after oil change Troybilt mustang 50 #2 It’s trying to shut down while mowing Are the sensors bad?
cpurvis Lawn Addict Joined Aug 25, 2015 Threads 21 Messages 2,256 May 22, 2020 / Reset oil meter after oil change Troybilt mustang 50 #3 Most installations which have maintenance minder devices have a reset feature. Have you done that? Check in your owner's manual.
StarTech Lawn Royalty Top Poster Of Month Joined Feb 19, 2020 Threads 79 Messages 10,272 May 22, 2020 / Reset oil meter after oil change Troybilt mustang 50 #4 Not all hour meter have a maintenance but instead an auto reset after a predetermined time has passed. Also need the model number from the serial number tag see how your mower is setup.
