The replacement coil comes in two parts, see picture below (plastic plug w/ wires and grounding (trigger coil), and field winding coil) I would like to use my old triiger coil and just order the field wire coil.
Why don't you just replace the old point coil converted to electronic trigger to the new magnatron electric module and not worry about installing the trigger on the older style point coil.
