I have a 17.5 B/S Intek with a Nikki Carburetor, The engine only runs for a couple seconds then stops. i cleaned out the carb but still the same thing, im going to replace the carb but not sure which one it is. my model is 31G777
Type is 0836 B1 ( when i look up it on the briggs web site it shows only 0036 B1 for the type) my code is 080530ZD so with this information i believe the carb should be Part# 794572 can anyone tell me if im correct on the Part#, also does a new Carb come with the fuel solenoid? all the Picture is see shows it attached
Thanks
Thanks
