Look up the specs for your engine .
The only important things are the shaft size and the height from the base to the shaft.....
If your hopper does have a flywheel PTO make sure you fit the blow out covers which your engine should have been fitted with.
If not buy a pair of them and cut the housing to fit them then most important, use them regularly to keep the cooling fins clean.
Gotcha. Ok, I'll check into that and what those places have to offer. I'm not sure what the "blow out covers" are. Mine has shrouds around the heads but I had to practically take the whole engine apart to get those off and clean the fins.
Thanks for your help.
I know you don't want to hear this but I like kohlor engines. I went threw 3 Kawasaki engines on a toro in less then 1000 hours. Went with a kohlor pro and after 500 hours put them on my other 3 mowers.
I have not liked Briggs since they stopped making the opposed twin.
I don't have anything against them, really. I'm a little miffed at how much you have to disassemble to get simple stuff off and some funky component placement issues. My main problem with them at the moment is the cost to replace one. I just don't have $1500+ to drop on a 20+ yo mower that still needs work in other areas. Still though, my dad replaced it with a Hustler and we all hate that thing. We'd much rather have the Grasshopper rolling again.
Thanks for the help. I'll take some measurements as soon as I can and see what's available. I was hoping that someone would say "oh yeah. this one and that one are direct replacements"
