My clutch on ZTS 7500 quit working all of a sudden. Wiring seems good. I had a belt come off and clutch would not work after I put belt back on. I understand there is only one fuse on mower and if it starts fuse is OK. Thanks for any help.
Find a wiring diagram. Just too many wires and switches to work without a wiring diagram.
You can also check to see if the belt damaged the plug on the clutch.
at PTO clutch itself,Fixing Electric Clutchesmechanic mark, Just for my curiosity, what air gap? Thanks
