- Feb 19, 2020
- Threads
- 111
- 12,257
For grinding off the blade nut a new 5/8-18 smooth flange nut will be required. Most hardware stores will not have this nut in stock but many mower repair shops should have it.Just a thought here.. If your needing to remove the blades and do not have an impact gun or breaker bar, would it not be easier to remove the pulley, then the 3 or 4 bolts that hold the spindle to the deck, remove the spindle with the blade still attached through the bottom, then either throw away the old spindle and blade and replace with new OR if you really really wanna save that old dull blade (that costs about 20 bucks to replace) put the blade in a vice and then grind off the nut with a 20$ harbor freight grinder... Or just grind it off while still in the tractor, goto the hardware store and get a brand new nut for 50 cents if the nw spidle didn't come with one? I mean if your replacing the spindle why not replace the entire assembly then it doesn't matter how you destroy the old parts..
Also don't remove the spindle housing if you are just rebuilding the spindle as the mounting screws tends to be seized and break off when you try to remove them. Once broken off usually the spindle would need replacing afterwards.
Personally I rebuild most MTD spindles with bearings and seals if needed saving the customer the price of new spindle assemblies.Especially when for an example the MTD 918-04865 spindles are $106.31 ea here vs the two bearing being only $7.43 ea.
