PeterJones
- Jan 3, 2017
- 11
- 58
Hi,
I have a Scag Cheetah which suffered a melted bottom bearing on one of the blade spindles. I've taken the easy way out (I thought) and bought three full spindle assemblies rather the replace the spindle bearings.
I've immediately hit a problem with the top collar around the spindle shaft (see photo). I removed the two bolts holding the collar in place and I assumed I could just pry it up but no luck. I've soaked it in WD40 - no change. Applied heat to the collar - no change. The collar isn't moving!!
Is there a special trick to removing the collar? It's part number 48926, Tapered Hub.
Cheers, Peter
Cheers, Peter
