tony norton
- May 26, 2021
- 3
I'm working on a Remington(?) model 13A277SF583 lawn tractor with a 4P90HUD 1708313A0436 MTD engine in it. The motor runs for 15 minutes and then dies. It will start right back up and then run for 5 minutes and then not until it cools right off.minutes. I thought ignition assy. but the last time it started to die I sprayed gasoline down the carb throat and it kept running. Thoughts? Valves, shut off on carb?
