cubcadet79
- Apr 4, 2020
- 1
- 4
Hello,
Just getting the mower dusted off today. I ran into a problem. I have a picture below.
So, I turned the key a few times and it lacked oomph.
A little background: When I turn and hold the key it usually (for the last 3 years) fires, pauses like it gets stuck, then right that instant I lift and then push down the throttle, then the firing resumes and then it starts.
So I tried this way of starting it, but there wasn't enough oomph.
I started smelling a little burning, especially as I inspected the battery (I suspected the battery was low since it's 2 years old and was left in place over the winter).
I touched the red positive cable and it was very hot. It was hot enough to melt some plastic around a bolt adjoined to the red wire. I don't know what the bolt is for.
Anyway here is the picture, it will help explain.
The green circle is where if you touched the wire you could tell how hot it was.
The red circle is the bolt that got so hot it melted the plastic that it was in.
The blue circles are the bolts that are holding the thing that the red circle bolt was in before it got super hot.
The white circle is the obviously corroded terminal with a possible crimp in the red cable.
One other funny thing that happened was i touched the red circle bolt to the frame and the engine wanted to fire.
So, questions are:
What caused this melting problem? The dirty terminal? Crimp?
Should that red wire EVER be hot like that?
Do I need to replace some kind of unit that the blue circle bolts are holding that seems to be where the red circle bolt was situated before it melted out?
Any advice on the starting issue that is 3 years old now so i don't have to jigger it to get it started?
THANK YOU!!!
So, questions are:
THANK YOU!!!
