Herman1972
- Jun 8, 2020
- Threads
- 1
- 1
The Spring Kit-Idler Bracket broke and request guidance on how and where to reconnect?
if its the drive idler then on the left side of mower, the frame rail just in front of rear tire you see a big hole next to a little hole. thats where the spring goes, hook it to the idler arm and then use a hook or heavy cord to pull the spring end through the big hole and slip the end into the small hole to hold it and release the spring. it takes a bit to stretch the spring so its best to set parking break to slack the main belt so you should make sure the pulley lets the drive belt sink all the way inThe Spring Kit-Idler Bracket broke and request guidance on how and where to reconnect?
