exotion
- Jun 24, 2012
- Threads
- 66
- 3,444
So what you are saying is that the RPMs never change when you get into long wet grass?
(( racing is the only sport that you need two balls ))
Hardly ever and when the sound does change it doesn't affect cutting power or walking speed it has never bogged down enough to slow the blade or stop completely. I am saying that pretty much everything else on the hrr seems to be put on there for the effort of cheap. I have replaced the front wheels with some with bearings. The rear tires with rubber hr215 the blades with microcut blades. Had to remove the pop washer from rear wheels. Add a couple washers to both front quarters and I've dented the deck
The only things I have been impressed with is the gcv160 and the smart drive. So between the two if pressed with an option I would go with the toro as the honda is kinda ..well cheap. I have not used the gcv190 and have no opinions on it but the toro briggs engine I have on my super recycler is also crap the only way I could suck any power out of it was putting a manual throttle cable on it and running it wot.
