Recoil spring for an HRS21-SVA. Honda
Go look for a real mower repair shop.
One that only does repairs and sells used mowers.
Take the recoil with you.
It is only a flat spring so there will be another spring which will go in the hole & do the job.
Down side is you will have to pay for the mans time so expect to pay at least 1 hour labour.
I have started doing this reciently as I have had enough of spending 3 hours finding something that will fit then being told it's too expensive they wanted a $ 2 repair.
Segway Bill
Thanks bertsmobile1. I did that. My local guy tried the closest thing he had and the second pull, it came off the cogged wheel of the starter. He has given up. I guess if I had access to a whole wall full of spring assortments I might find one close but don't have that option.
