The whole point of a key, apart from a Scotch key is to shear before the shaft / pulley / whatever breaks.
So the key used needs to be weaker than whatever it is protecting
Even drive keys like in the axel will shear before the axel breaks.
The flywheel key was designed as a safety feature when flywheels were smaller & lighter.
So on a walk behind, the cast zinc keys are needed.
On a belt driven ride on they are not needed from a purely engineering point of view because belts will slip or break
