I've got a 92 toro 22" (20107) recycler that's been through the wars...we've been running it for 20 years now.
It has lost power to the point that it's almost unusable. I rebuilt the carb last year and it was obviouse due to the wear at the butterfly valve shaft that the carb needed replacement(couldn't get the valve off, the screw was locked on shaft, so couldn't replace bushings). I'm considering doing a complete rebuild on the engine (rings, valves, carb replacement, possibly bearings)
I need a reality check though, is this a worthwhile endeavor? Feel free to share your thoughts :smile:
