Repairs Rear wheel removal on a LT 11 36.
Is "never seize" the name of the product?
I have Brake.Away that I used to help get it off.
But it took a 12 ton press to get it off. Then it first
started to move it sounded like a gun had gone off!
I have a peerless trans axle that has both wheels
stuck on it. I may just open it up and remove both
axles to get them off. The wheels are 8x10x20. I
want to put them on the LT 11 36.
:smile: Yes, that is one name. Some people call it Anti-seize. Also some people use Axle/Wheel bearing-Grease. I have also split the transaxle case and used my 20 ton press, after soaking with PB blaster for a couple of days. It sounded like a cannon going off.
I removed this one using a drill, a saws all to split the hub and a couple of wedges driven in the kerf. Another method I've read is to weld a nut on the hub and use the threads as a pusher but I've never tried that so I can't comment on the success of that method.
:smile: There have been several the I had to use the gas wrench to cut the rim off the hub center and then use a cut-off tool to split the center of the rim hub. This is after all over methods have failed. Of course that requires a new/used rim as a replacement.
