Texas Bear
- Mar 10, 2013
- 7
thank you, T.
can transmission arm be switched while deck still on to not bother with taking it on and off?
is there some sort of safety switches, which can be bypassed, or is it hardwired?
btw. on raven.mpv. channel, gears. seems no switches... Changing Gears on the RAVEN MPV - YouTube
You can leave the deck on to access the transmission arm, but it's just easier with the deck off. Also, you can leave the trans arm in the mowing position (closest to you), but you won't be able to gain higher speeds. The arm position (away from you) will let you get up to the 17 mph. I'm unaware of any bypass or safety switch, I believe it's internal to the transmission.
