mhavanti
- Oct 12, 2014
- 924
You guys all do as you please, however, you can change the oil filter and leave the oil in the engine and add oil to bring it back to the correct operating level.
Here in lies what you are all doing to your engines. The oil filter becomes contaminated and no longer capable of cleaning the oil. If the oil has carbons, metal fragments and you drain the oil in a horizontal plane such as your mower engines, you will not remove all the fragments, unused fuel, carbons metal contaminants the filter will need to capture at some point.
However, that is NOT going to happen if the filter is not clean enough to capture all those contaminates. The filter is at its best the first 10 minutes and from about that time or even less, it is then fighting an uphill battle to do the job of defending the engine from the contaminates flowing thru the oil.
While I was in the machine shop business I loved all you guys that didn't change the filters often. You kept my machine shop very busy grinding crankshafts, boring cylinders, etc. from all the seriously bad engine oil maintenance I'm reading here.
Change your filters if you don't change the oil.
Have a glorious day.
