Hey 577jersey, I take it you are Kawasaki crazy. That's OK, I am Chevrolet crazy and just adore Drag Racing :thumbsup:
I may have chose a Kawi myself but it is no longer an option on the Raptor SD.
I needed a new mower, I needed to upgrade to zero turn, I needed to upgrade 42 to 54" and if $$$ were no problem
I would have chosen a Fast Track with Kawi engine - But - this if for Residential use only -
I do have tough Pensacola Bahia like is used in pastures hay fields and roadside erosion prevention.
I would wager it is the toughest grass in the world with roots over 3' deep. If it rains it grows seed tassels 2' tall in 2 days,
If not controlled will reach in excess of 3' tall and thick enough to choke down a bush hog.
So I needed a Heavy Duty - Zero Turn but I don't have a commercial budget. It took a lot of saving to get the Raptor Super Duty.
I hope it does the job but it will have to do it with a Kohler. "I think it will" just hope it last a long long time .
Will let you know
Dave
The 7000 has plenty of power,,its a great engine..I only have two kawis now and both are fairy low hours,,one has 80 hours the other on my RSD has about 50,,so far so good but I cant really tell you the new ones are good,,I did have older FC420V's with over 2K hours on them and still running strong,,one was even 6ft under in a river flood..lol..I can only hope the newer ones are half as good,my dad still runs my first Ferris walker with FC420,I put 2k hours on it back in the 90s and he has been cutting his lot with it for years now...cant kill those old Japan made 420s man,,best single Kawi ever built IMO
Good luck with your new machine brother,,i have one and use it everyday,,love it so far...as long as you take it easy on rough terrain and dont mind a little windrow in tall wet stuff once in a while you will be fine...I cut some pretty scary sloped lawns with mine,,if the mower doesn’t hold the bank I just ride up and cut back down,sometimes on a slight angle...8 PSI in rear tires causes a slight belly and works great!!
I dont think you have too worry about banks in FLA..pretty flat down there
[/QUOTE]
