Raptor 54 SD problem
kraky
Hey jersey ..... how do they brace up your bobcat? I still can't believe I live in Wisconsin and the Bobcats are made in Wisconsin and there isn't a dealer anywhere around....geez!
577jersey
I dont own a bobcat CRZ yet thats supreme from youtube who has one,,i bet they are pretty tough,its a big mower.
I do have a bobcat 48 classic walk behind.
kraky
Oops.... somehow I thought you were running a bobcat and the SD and liked the Bobcat better and were going to replace the SD when the time came. My A.D.D. won again!
turboawd
well, even the grade 8 bolts are breaking. this is getting aggravating. i think the cause is the weak frame and mounting points. there is too much flex going on. i need to get this resolved before the trans casting breaks, because then i'll be really f*cked.
i see that the cross brace has been upgraded on hustelr's site.
part# 118942 to 123292
but the bracket doesnt look too different. there needs to be a support going across to the outer mounting points of the trans.
Carscw
Lol
Sent from my iPhone using LMF
Ronno6
Does this brace fail due to bolt loosening or bolt failure?
Would replacing with grade 8 bolts installed properly reduce or eliminate this failure scenario? \
Does the likelihood this failure to occur vary depending on terrain?
BlazNT
Answer 1 Both, Bolt loosens and the shearing force snaps the bolt.
Answer 2 Yes if you check the bolt tightness ever once in a while.
Answer 3 Not real sure on this as most of the problems posted here do not explain their terrain.
Ronno6
I wonder if a piece of 1" diameter cold rolled steel spanning the hydros inside the ears of that bracket,
drilled and tapped 3/8-16 and bolted into place would eliminate the problem, or would it need to be welded to the cross brace itself?
Just tossing around the idea....
BlazNT
I will get a picture of how my Husqvarna is set up so you can see how easy it is to fix.
turboawd
There is another thread where I posted pics of the updated bracket which you can get for free from your dealer.
