Nothing will make you pull more hair out then a champion plug. The only plug that used to list a 25% misfire within acceptable range of operation in their spark plug catalog.Well here's the solution to the random misfire. It was the new Champion spark plug. The customer has installed a new plug while to troubleshoot the carburetor problem. New NGK 2460 installed and its purrs right along with no random misfires.
As we always say new don't always means good.
Now one chainsaw carb was filthy, the other was incorrect plumbing and incorrectly tuned. Now just started on the generator and its carb is a mess.
