Random dead miss.
I get back to the misfire in a few days. Just did the transaxle today; install new needle bearings, input shaft, and drive shaft [forward reverse assy]. Also added grease.
Now that a Honda generator and two Husqvarna chainsaws came in today those got to be checked out for what parts I will for them.
Well here's the solution to the random misfire. It was the new Champion spark plug. The customer has installed a new plug while to troubleshoot the carburetor problem. New NGK 2460 installed and its purrs right along with no random misfires.
As we always say new don't always means good.
Now one chainsaw carb was filthy, the other was incorrect plumbing and incorrectly tuned. Now just started on the generator and its carb is a mess.
Nothing will make you pull more hair out then a champion plug. The only plug that used to list a 25% misfire within acceptable range of operation in their spark plug catalog.
About where this one was at, No wonder I switch to NGK years ago. The only NGK I have problem with is those 10mm ones.
