Onefastmower
- Jul 7, 2012
- 4
Hi I'm working on building 2 tractors one drag tractor and one pulling tractor has anyone ever built one of these before I have a Honda 20 horse v twin that I plan on twin turboing with two carbs using smart car turbos very small turbos only using 4 lbs boost each for the drag mower and for the pulling tractor I have a 20 hp b&s ic opposed twin that runs on alky right now the question I have is what would the best trans be for both of the tractors money is not an option as I already have two grand into the Honda and about fifteen hundred into the b&s twin I plan on building tube frames for both and using go kart steering so it will be safer at higher speeds also what size pulleys should I use and has anyone ever used dual or step pulleys before
