I have an R 220T which I bought used. To my surprise the owner's manual does not have a diagram for threading of the belts on the mower. The three look pretty obvious but I am not sure about one thing.
Looking at the illustrated parts list ( http://cdn.husqvarna.com/ddoc/HUSI/HUSI2012_NAaa/HUSI2012_NAaa__19.pdf ) page 20 belt 1 runs from the engine pulley to an intermediate pulley, belt 2 runs from that intermediate pulley to another intermediate pulley which also houses belt 3 which runs up to the cutting deck.
According to the parts manual belt 3 goes above and belt 2 below on that pulley. This also make some sense as part 18, the belt guide covers only the lower pulley and it is belt 2 which is loosened to disengage the mowing blades.
So I guess the routing is clear but I have one question. Belts 2 and 3 both run more parallel to their next pulley if belt 2 is on the upper pulley and belt 3 on the lower.
Is it possible that the parts manual is incorrect? I reversed the belts and have noticed no problems, although the illustrated routing works too. The belt guide does make me think the manual is correct but asking just to make sure.
Thanks in advance,
Haywood
Thanks in advance,
Haywood
