Well... after a couple of false starts last weekend the owner finally dropped off his 721D at my place yesterday. It's in really good shape. The only "bad" things I noticed were that the left front floating wheel on the deck was missing and that the mounting bracket was pretty badly bent. He had the deck wheel with him, so all I'd need to do is remove the bracket and beat the hell out of it with a BFH to straighten it again and then re-install the wheel and it should be just fine. Also, a few small rust spots that could use some touch-up paint. And of course some paint polish with a couple coats of wax and rubbing some Armor All into the seat and on tires, hoses and other rubber bits & pieces would go a long way towards making the old girl shine like new again.
The blades do need to be sharpened or better yet, replaced. He told me that the best mow he ever got with it was while using Gator Blades but that the current set are generic type; a few years back one of the Gator blades was damaged hitting a rock and he just put a set of "regular" style replacements on due to cost. I do notice that although it does a great job gutting grass it doesn't cut buckhorn weeds worth a poop. Odd, since my Deere would slice them just as well as any grass or weeds. Perhaps this is due to the dull edge of the blades, or the style of blades currently on it? So while I'm thinking of it, do you guys recommend med-lift, hi-lift or Gator type blades??? Grasshopper suggests using their brand (obviously). The literature they sent me says that their blades last up to twice as long as typical aftermarket (Oregon, etc.) blades. What do you 'Hopper owners say to this claim? Also, what are your thoughts on using Grasshopper brand filters & oil versus non-GH syntheitic oils & filters? Is the GH stuff really that much better?
Other good things I discovered during my inspection of this 721D machine are:
Deck engagment clutch is brand new; the right pump motor was replaced 3 years ago; left pump motor was replaced 2 years ago; engine tuned up last spring. New fuel lines this spring along with all new Grasshopper brand filters. The seat is in like-new condition: no wear, tears or rips. The chevron-style tires are a little worn, but after all they're 14 years old so that's really no surprise. After a test mow last evening I am seriously tempted to replace them with a set of the same Carlisle tires I put on the back of my Deere GT235. Those have excellent traction in slippery stuff but would be a lot more forgiving on my grass in those zero turns.
Oh, and another good thing, the 'Hopper tackled the slopes along my ditch that I was initially concerned about with NO problems! After giving the mower a thorough once-over (twice) and seeing it in action I am thinking that I'm gonna buy it. Even though it's 14 years old I think his asking price ($3200) seems reasonable considering the low hours and overall very good condition of everything. If it all works out I am hoping I can get one of my two local Grasshopper dealers to do an even trade: my 1999 John Deere GT235 for a 721-compatible snowthrower and maybe even one of those manually-adjustable Little Bully 60" blades, too. New or used doesn't really matter to me, just as long as they're in good solid working order. I'll try and get some pics of the machine posted up for you all to look at today or tomorrow.
Thanks everyone for all of the helpful advice on this purchase!! :thumbsup: I'm sure I'll have more questions as I go!
