Mower makers do not make belts... They use standard or spec belts...
You likely have a classical V belt 'A' or 'B' size... as to the length, do as LandN & noma suggested... place a rope around all the included pulleys, pull it taunt and measure it... ANY Industrial supply or Bearing supplier in your area will be able to give you the exact belt you need...
You can also go online ... places like: ... V-Belts; Metric V-Belts, Power Transmission Belts;Synchronous Belts;Timing Belts;Industrial V-Belts;Low Cost;Discount Prices
They will have your belt for around $5.... Do a little measuring and you will find how easy it is to find a correct belt size...:smile:KennyV
