Ric
Hi -
I don't know what spindles are.....
Kentucky bluegrass, I believe
The spindles are what the blades are bolted to and I'm not real sure if they have the fittings so they can be greased or if there sealed bearings or not on that mower. I've been watching this thread since it's beginning and some of the answers are right on but the fact is there are numerous other things or reasons to look at or for as to why the mower is not cutting right.
My recommendation would be to find a dealership with a good service department that you trust and have them check the mower from top to bottom. Look at the spindles, pulleys, belts, tension springs etc. make sure you don't have a bearing issue and make sure the deck is level and have them install new blades. If the mower has been trouble since you purchased it most of what I have suggested should be covered under your 2 year warranty if the mower isn't right with the exception of the new blades. Again as primerbulb120 already stated leave the chute in place unless you want to be open to a lawsuit.
