Putting Tubes in tubeless lawn tractor tires
Rdr202
For anyone that doesn't have a valve stem retaining tool handy in his tool arsenal, there is a good quick inexpensive way to make one. It doesn't matter if the stem goes back inside because it can usually be retrieved.
4-way stem valve tool is only $1.49 at Auto Zone p
SeniorCitizen
Not many live across the street from Auto Zone. Example : I'm about a 60 mile round trip but I wouldn't step through the Auto Zone door again if I did lived across the street.
Usually I find if you remove the valve core & use an air duster with a large hole, the air will enter fast enough to make a seal on the beads.
Some times I need to pu a strap around the tyre and even jiggle it back & forth to get the beads to touch some thing solid & take.
The reason for the small air tank tyre inflators is to prevent injury to the tyre fitter .
Most tyre shops and a lot of workshops will have a large air receiver on the end of the compressor .
Mine is around 100 gallons.
So if some thing goes wrong, 100 gallons of air at 150PSI will instantly try to become 100,000 gallons of air at normal atmospheric pressure which is effectivly a bomb.
It is ot odd for a tyre shop to have compressors running 200 psi so the fitters can not draw air faster than it can be supplied and you don't want to be around when that lets go.
