I took a vertical shaft Honda engine off of a power washer. I want to put it on top of a lower end of a boat motor.
My question is what do I need to do to put a throttle controller to operate the speed?
The honda has an automatic choke and won't rev up till you start spraying so I need to put a throttle on it too.
I haven't studied it enough just hoping to get suggestions.
Putting the motor on the lower end was easy, even for me.
