I have been poking around this forum for a while and have ended up here numerous times while searching for mower advice. My apologies if this is not the correct place to post this thread. I thought his was a good crowd to judge this idea of mine though. The idea is for a push mower which would easily convert to a walk-behind leaf blower. The mower would look just like any push mower but the discharge chute would be 90 degrees to the push direction instead of 45 degrees like most mowers. You would then take the blade off and put on an impeller and a shroud over the main opening that has a smaller diameter epening in it. This would turn the deck into a centrifugal fan, just like the ones used on a standard walk-behind blower. It seems like if you were buying a new mower and there was one that had the ability to turn into a high powered leaf blower with a (roughly) $75 add-on, that most people would purchase it over a standard mower. So...would you buy it? Any input would be greatly appreciated.
P.S. This is not a product that I am trying to sell, just an idea at this point.
