- Nov 29, 2014
- 65
- 24,995
Got a 2007 JD 425 Z track with the sideways engine and a DUP 10 E pump driving a pair of wheel motors ( M0Z425J040186 ) /DUP10E # 10E035050
It wrapped up some wire around the drive & clutch , ripping the clutch off
So it got pushed around a lot because the owner is trying an insurance claim against the NBN installer who left all of the old wire on the ground
So it has been to 3 repair shops for quotes with the clutch hanging off the PTO shaft
So I have got the clutch off, dressed the shaft fitted the new clutch well & good
But no drive to the right wheel weak drive to the left .
So I tried the F-R-F-R bit , pump bypass valve open
Then the same bypass valve closed , no difference to right but left came good
So I have run the right , engine at slowest speed for over 1 hour F-R-F-R-F ( wheels off the ground ) but still no drive to the right wheel .
Seems the DUP10E was made in Japan by KANZAKI but I can find no service details
Any one got some Ideas
Only thing I found on line was 15 min in each direction at low speed .
So we all are on the same page, this is a single pump with a pair of plumbed wheel motors and the oil level is right where it should be
