grumpyunk
Certainly you can try to run the pump on 120vac. There should be a diagram indicating how to wire power when set to the 120vac setting. Likely you will have line & load & a ground. Connect that way, switch the selector to 120vac and it should work.
It could be there is a fault in the motor where one leg of the 240 has a break, either a broken wire or loose connection. Give it 120, and it doesn't use that conductor, so it works. Try the 240 and you are applying two 'hot' leads, and apparently the switch is sending power... but it doesn't run. Likely one leg has taken a hike. (get it)
tom
tom
