willys55
- Nov 11, 2016
- 8
- 1,053
you didnt change the plug, could be bad plug or weak magneto.Hello folks
I have a 1979 5Hp Briggs flat head on a chipper/shredder that runs well albeit rich. It turns the spark plug black. It does not blow black smoke. I have cleaned the carb as best I could without removing the welch plugs. I removed and inspected the fuel pump membrane and it looks really good for its age, no visible tears or holes.
I was given this chipper as it was sitting inside for 15 years. I did the obvious things - new foam air cleaner, new muffler, cleaned carb, cleaned fuel tank, changed the oil, all looks pretty good. I did notice that the exhaust valve lash is a bit over spec at .013, intake is fine.
Other then the pump membrane, is there anything else one can do/check to help solve this running rich issue. If the jets were accessible, I would try that. I have run about two tank fill's of new gas with a little marvel mystery oil in it. The oil get dark pretty quickly too, maybe from running rich. I don't believe that this motor has that much time on it for its age.
Thoughts?
that's the most of my internet superpowers I can share with you.
FYI : Don't be so thin skinned, this is the internet and that limits just how helpful people can be, we can't touch or see what you see, so the more info given from the very beginning the better.
