Hey all, I have a 24 B&S Vtwin INtek in which the cylinder 1 exhaust valve is barely moving. Pushrod is fine, so I suspect the Camshaft Lobe. Anyway, I have removed the engine which is upside down on workbench right now. I have of course removed the clutch and bolt no problem, but cannot get the upper pulley to budge at all. I have soaked it for 2 days with pb blaster, there is no set screw in it. I picked up a 3 finger puller at parts store, but it just bends the pulley. Tried to heat it, still nothing. Am I missing something. the crankshaft has a groove in which I suspect the pulley has a rise to fit in the groove. Any ideas appreciated. Would like to get this thing fixed......Thanks!!
