PTO
kandar
Blades should stop but keep going when I go in reverse, CUB CADET. ???
Cub Cadet covers thousands of different models with different configurations. How about the model number from under the seat so we can see what system you are using.
kandar
Cub Cadet LT 1045 HYDRO DRIVE MOD# 13AX11CH056 621-879
NorthBama
check for broken wire going to reverse switch at right side rear under seat pan near transmission
NorthBama
this picture is for a LT1054 not sure if is same as Lt1045 you can take a look see
Haulero
I don't see that as a problem.... I know it's a safety feature but I rather to be able to mow in reverse.
