Blades should stop but keep going when I go in reverse, CUB CADET. ???
K kandar Forum Newbie Joined Jul 8, 2012 Threads 3 Messages 6 Sep 9, 2019 / PTO #1 Blades should stop but keep going when I go in reverse, CUB CADET. ???
I ILENGINE Lawn Pro Joined May 6, 2010 Threads 39 Messages 9,940 Sep 9, 2019 / PTO #2 Cub Cadet covers thousands of different models with different configurations. How about the model number from under the seat so we can see what system you are using.
K kandar Forum Newbie Joined Jul 8, 2012 Threads 3 Messages 6 Sep 9, 2019 / PTO #3 Cub Cadet LT 1045 HYDRO DRIVE MOD# 13AX11CH056 621-879
NorthBama Well-Known Member Joined May 28, 2014 Threads 9 Messages 932 Sep 9, 2019 / PTO #4 check for broken wire going to reverse switch at right side rear under seat pan near transmission
K kandar Forum Newbie Joined Jul 8, 2012 Threads 3 Messages 6 Sep 9, 2019 / PTO #5 NorthBama said: check for broken wire going to reverse switch at right side rear under seat pan near transmission Click to expand... Only found one wire, the one that shuts it down when you get off the seat.
NorthBama Well-Known Member Joined May 28, 2014 Threads 9 Messages 932 Sep 9, 2019 / PTO #6 this picture is for a LT1054 not sure if is same as Lt1045 you can take a look see
H Haulero Forum Newbie Joined Aug 26, 2017 Threads 1 Messages 2 Oct 6, 2019 / PTO #7 kandar said: Blades should stop but keep going when I go in reverse, CUB CADET. ??? Click to expand... I don't see that as a problem.... I know it's a safety feature but I rather to be able to mow in reverse.
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,411 Oct 9, 2019 / PTO #8 https://www.cubcadetpartsnmore.com/cub-cadet-service-manuals scroll down page for cub cadet lawn tractor service manuals, see pages 73-77.
